I'm noticing small droplets of brake fluid on top of my brake fluid reservoir when I open the front trunk. Since the droplets are on top, I don't think I have a crack in the reservoir. Does this mean I need a new cap, or do I just need to close it more tightly?
Could be a bad seal on the cap.
Also when did you last change the brake fluid?
I changed the brake fluid last week. I had the droplets before the brake fluid change as well. Should I get a new seal for the cap, or get both?
