What is the exhaust tube diameter?
I.e. what is the diameter of the bypass pipe that fits into the stock exhaust - to put it in another way :)
Thanks in advance.
Nobody knows this?
Well, I guess it's rather evident what I plan on doing: going to a local muffler shop and get a ready made pipe or make them bend a proper one and then fitting tips into those. Cheap-o bypass pipes in mind...I do love the quality of the fabspeed ones but almost $500 is a LOT for two bent pipes and a pair of tips...
If someone knows this - please do post...
take off ur mufflers and measure it.
it looks like 3" roughly, but better you measure it to be presice.
Yep, that's what I had in mind but I was just posting here to take my chances if someone would know the measurements already :)
I'll measure it today and I'll post the results later on...should anyone else need to know...
  • 14 years later...
55mm or 2.156 i believe is what i read but i am not sure if that is OD or ID? Apparently only a 2.25 is most commonly available.
