Cabin filter Replacement
Instructions in photos. 1. Open glove box to reveal location of the torx screw holding cover in place (it is located near the bottom edge of glove lid - you can see it after lid is opened) 2. Remove screw - socket - T20 - one screw in center of cover edge 3. Gently pull down on cover with fingers on left and right side of cover to remove pressure clips holding it in place. 4. Remove 2 screws with socket 5.5mm. This removes the closing cover to the filter compartment. 5. Remove filter c
  • Like 1
