We just bought a 2004 Carrera 2 Targa. At first, the rear hatch would open fine, then it started sometimes not opening, and now it refuses to open.
The car came without an owner's manual (we have ordered one), and I have been unable to fine a .pdf version anywhere.
Any help would be much appreciated!
Mark
:welcome:
We have an MY03 Operators Manual - which should be pretty close.
Start by checking fuse D3 - should be 30 A.
If it is truly intermittent then you will likely need to find someone with a Porsche PST2 or Porsche PIWIS tester.
That diagnostic can test and confirm exactly where the problem is without guessing.
Thanks for the greeting, Loren, and even more thanks for the owners manual. It turns out that the hatch was intermittent, because I didn't know (without a manual) that it won't operate with the targa roof open.
Now I do know; and I'm learning all sorts of other things, also!
Mark
