I'm going to replace the CD-220 head unit with a Kenwood BT-901.
Planning to keep the Porsche DSP unit that was standard and I want all 6 stock speakers and amp to continue to function.
I bought the unit from Crutchfield and also got the Porsche wiring harness. So far so good. Even noted to switch the red/yellow wires and connect up all the blues...
I see the BT-901 has 4 plug outputs which are meant to go to the amp (marked RF, LF, RR, LR) via one harness connector.
There is another harness connector which has 4 wires connected which are for RF and LF speaker connections.
Do these 6 connections (4 to amp and 2 directly to speakers) work exactly right to what my amp and speakers are expecting?
If the answer's no, please explain!
Thanks Thanks Thanks!!!
