My 99 boxster seems to be losing coolant. There appears to be a coolant smell while driving down the highway when the windows are cracked. When I look at the areain the trunk around the cap after a drive it is wet and appears to be loosing pressure around the cap
It was a newer one not long ago from pelican parts
I have heard of a bad batch of caps but I have tried about three
What is the latest part number for the latest cap?
I meant coolant cap sorry
Make sure to also check that the area around the pressure relief valve housing is completely dry and that it does not show any dried up residue. The O-rings and the rubber gasket under the pressure relief valve are also known to fail on occasion.
You can check on this by removing the thin black plastic cosmetic cover that sits on top of the coolant tank. The pressure relief valve housing is just forward of the coolant cap and, if it's leaking, there will be residue at the base of the housing and/or around the screws that fasten it in place.
Regards, Maurice.
