Hey Loren is there any specs or instructions in the diagnosis of the coil packs and the extension tubes, i.e. how to look for signs of wear or cracks? Is there a way to test the coils to see if they're within spec? Like checking the resistance or someting? Thanks I am going to change the plugs again, and want to make sure everything down there is 100% :)
Not that I have seen published. I guess you could read a new one and then compare but when one of these goes bad it usually very obvious - with a huge difference in readings.
ah, good idea. Thanks I will do. I think the more important thing is to check for cracks is what I have been told I can use alcohol and see where it seep. I will do both as well with the tubes- :)
