Front:
5x130mm bolt pattern
8.5x18 et. 52
Rear:
Cup 3 5x130mm bolt pattern
10x18 et. 65
I know the front and reat ET don't match the stock specs, but would this still safely fit?
Thanks Loren. Seems that size is not recommended, but wonder if anyone is running the setup. Only looking to use them for 2-3 months a year in the winter.
You could run those rears on a narrow body 996 for winter -- but the 8.5 wheel on the front would something Porsche does not recommend. No room for chains or snow buildup.
For your 996TT I would suggest you stay with the factory recommendations.
