Hi I had my 2006 V6 Cayenne Air compressor replaced. I opened the hood and saw that a screw is missing on the belt tensioner. Any help is appreciated.
post-28784-0-07038300-1343054286_thumb.j
Did the shop/person that replaced the compressor lose it?
From here it looks like 948.102.901.00 Torx screw M10 x 28 -- US MSRP $3.31
Edited by Loren
My mistake - this is the V6 engine.
That threaded hole is only used to adjust the belt tension when you r&r the belt.
You put a bolt in there to adjust the belt tension then tighten down the 3 screws on the arm to hold that position.
So normally there is nothing in the threaded opening.
