I've searched and tried many of the suggested fixes but still have the folowing issue. I checked the B row fuse for locking and also the 15A external fuse under the drivers seat on alarm module.
*EDIT* I thought the door switch was root cause of my key fob not working. Update is the door switch does work when car is running (sorry thought ignition was enough) Still not sure why fob not working for unlock. I hate always settting off the alarm.
Edited by 987_RDC
Did you verify the switch to see that it's connectors are on and clean (remove switch).
Sometimes previous owners disconnect a switch to hook up their radar detector, etc.
Turns out that switch does work but car has to be running. Checked E1 fuse and is fine. Seems the remote that came with the car doesn't work. Took apart and resoldered too. Resoldered connections on alarm box too, didn't make any improvement.
