My Porsche Targa has electric problem with the high low beams.
I have checked the fuses,
the voltage to the +ve terminal for the fuses w/o the fuse in place,
the continuity of the -ve terminal of the fuses to the headlight assembly female connector at the car frame,
the voltages on the female connector with the light switch on and light (high/low) level nd
the ground continuity from the 1-12 ports on the female connector at the car frame to the main ground.
The problem with the power to the low or high beam continue.
I need the wiring diagram for this car to solve the problem or if someone know a web page tha t can give me some ideas.
Thanks.
Thanks, that is my next task. I need to remove the front wheel and front fenders liners to have access from the connector and push forward toward the headlight assembly.
Nevertheless, the complete wiring diagram will be helpful for this and other issues.
Again, thanks for your help.
PM me with your email address and I will send you one. I think I can figure out which one you need as there are about 20 pages of diagrams .
