Stuck in gear and loose shifter
About a year ago, I was parking my 2003 C4S and it got stuck in gear (1st or 2nd... I can't remember). The weird thing was, the stick became very loose and could move all over (like stirring a pot of soup) but it was stuck in gear. I finally got things back to normal by just moving the stick around a bit. I then put in a B&M short shifter and the problem seemed to disappear... until yesterday. It got stuck in 4th gear this time and again the stick was loose and could move all over. I then moved the stick into reverse and it shifted just fine and was back to normal after this... but trying any of the other gears didn't seem to fix the problem - only until I shifted into reverse.
Anyone with any thoughts on the culprit?
I haven't checked under the car yet. Do you mean where the shifter cables attach to the transmission? Do I need to remove any panels under there or is it in plain sight? I have seen some pix in here on how the two cables attach to the transmission but I'm not sure they were pictures that would apply to my 2003 C4S.
Thanks for the tips!
