I notice my 2001 996 top won't retract at anything other than stand still. Has anyone tried work arounds to allow retraction of the top when moving? It would be very convenient to have this feature when going in virtually standstill traffic on a hot day, for example.
There is a hack developed by Pedro that allows the top to be operated while moving in a 986 Boxster which involves bending up one of the spades (pin #18) on the convertible top double relay. Porsche incorporated this feature in the later 987's, but this hack works on 986's.
I don't know if you could do the same hack on a 996, but you can check this out if it interests you: http://pedrosgarage....-in-motion.html
Regards, Maurice.
I do that at very low speed by lifting the hand brake by just 1 click. That way when I am at a red light, the top goes up or down and car behind me don't wait even if the traffic light turn green before top as finish is cycle. :thumbup:
Yes, SmartTop will do this but why? I live in an area where 40 mph wind gusts are normal, and Semis get knocked over often (northern Utah). A wind gust would destroy the top. I don't activate the top when it is windys or while in the canyons.
I live in Boulder where 100 mph wind is a stiff breeze (chanooks)...what does that have to do with retracting a roof while driving? I wouldn't even attempt to drop the top in those conditions whether I was moving or not (nor would I want to). The SmartTop does multiple things:
1. One touch operation (you don't have to hold the button
2. Allows use of rear window operation
3. For earlier cars, operation up to 35mph (this is and has been available on stock Porsches for about 10 years I believe MT2002+)
Edited by wross996TT
I bought a SmartTop 4 - 5 years ago for my 2001 996 and followed the simple installations and I absolutely love it. It will work under 20 MPH and required only one touch to raise or lower. A few years ago, I had a new battery installed and it would not work. Found the original paperwork, e mailed the company and immediately received re-install instructions. Took a few minutes and it is operating perfectly again. Ed
