Hello everyone
I was wondering if anyone has the panel gaps for an 08 c4s. the car is having some work done and i wanted to restore the original panel gaps on the right front corner once everything is reasembled. is this info even avalible or should i just eye ball it????? thanks!!!!
Hi there I have what you need but it is in the workshop manual in PDF, I need to find a way to cut and paste, there is a security lock
Worst case I will do it manually over the week end
See what you can do with this
I had to copy the pictures separately so it is not perfect
I double checked, but the description ( e.g. front lid to wing) should always match what you have on the picture
Good luck
50 IN Diagram - body gap dimensions - as of MY 2005
- Diagram - body front gap dimensions
- Diagram - body centre gap dimensions
- Diagram - body rear gap dimensions
- Diagram - Cabriolet gap dimensions
Tools
Designation Type Number Explanation
Star gauges for body gap
dimensions
commercially
available tool
NR.127-1
top of page
Gap dimensions, body front
Note
Set gap dimensions on the lids, doors and covers, or accessories in accordance with the gap
specifications.
Given a clearance in the opening that is too great or too small, the movable body or the accessories
must be centred accordingly.
· Ensure that the gaps do not taper or do not narrow at local points.
· The given values are guidelines which should be observed as far as possible.
· The guidelines apply to repair and assembly work.
· Use star gauges to measure the gap dimensions, Star gauges for body gap dimensions NR.127-1
lid to front apron
Explanation Type Basic value Tolerance 1 Tolerance 2
front apron Gap dimension A 4.5 mm +/-1 mm
front apron Lid only lowered Gap dimension B 2 mm
Main headlight to inner wing
value
2
to inner
Determine left and right
gap
Gap dimension
A
4.5 mm +/-1 mm
Diagnostic system: reading out fault memory and activating systems
dimensions, body front 4710
headlight to front apron
Location Explanation Type Basic value Tolerance 1 Tolerance 2
Main headlight to front apron Gap dimension A 4 mm +/-1.5 mm
Main headlight to external wing
2
wing
Gap dimension A 4 mm +1 mm
wing
Only lowered Gap dimension B 1 mm
Main headlight to top wing
Main headlight to top wing Gap dimension A 4 mm +/-1 mm
Main headlight to top wing Only lowered Gap dimension B 1 mm
Front lid to wing
Front lid to wing Gap dimension A 4 mm +/-1 mm
Front lid to wing Only lowered Gap dimension B 0.5 mm
Wing to front lid
2
Wing to front lid Determine left and right gap Gap dimension A 4 mm +1 mm
Wing to front lid Only lowered Gap dimension B 0.5 mm
flap to wing
Filler flap to wing All the way round Gap dimension A 3.5 mm +/-0.5 mm
Front apron to side direction indicator
value
2
indicator
Gap dimension
A
1.5 mm
Wing to side direction indicator Gap dimension
B
0.5 mm +0.5 mm
Wing to outer side panel
value
2
to outer side
panel
Even transition from front
to rear
Gap dimension
A
4.5 mm +/-1 mm
top of page
Gap dimensions, body centre
Note
specifications.
Door to wing
Door to wing Gap dimension A 4 mm +/-0.5 mm
Wing to outer side panel Gap dimension A 4.5 mm +/-1 mm
Wing to outer side panel Only lowered Gap dimension B 2 mm
Door to outer side panel
Door to outer side panel Doors only lowered Gap dimension B 2 mm
Thanksss so much for the infoo so farrrr!!!!!!!!!!! just one question is there a way to buy or download the workshop manual you mentioned?? thanks
