Cayenne Turbo rear brake pad and rotor DIY
Tools needed: 2 - Jack Stands factory jack or floor jack (not shown) Breaker bar or pipe for tight bolts 1/2" ratchet 3/8" ratchet 4" extension 1/2" drive (roughly) 3" extension 3/8" drive (roughly) 3/8" to 1/4" adapter T-50 Torx bit M16 Triple Square M5 Triple Square 19mm Socket Wheel Lock Socket 5mm Allen key 1.5mm Allen key Pair of pliers or good multitool razor blade or knife Brake Cleaner FLASHLIGHT Optional: a good set of allen keys - obviously mine are craftsman a
