I have the wheel liner out...Can't find washer pump. Is it behind the washer tank. If that is the case, it may not be getting changed.
I got hit awhile back on the drivers side and I bet the body shop shut the pump behind the washer tank.....if it's not suppose to behind it.
Are you asking where the washer pump is located? It's connected to the washer fluid reservoir. Disconnect/remove it to access the pump.
