any one know where to get a new, cheaper drive shaft? I replaced the carrier bearing but now it needs to be reballanced and I can't find anyone to ballance the shaft here in Buffalo NY. I may sell after I replace it.
theyre right next door to me and I asked if they ballanced those shafts. They said they dont ballance european shafts like mine.
Try vertexauto.com. A new shaft from Porsche was pricey (about $1200). Vertex has a little beefier one that is only $400, cheaper than replacing the carrier bearing and should not require a balance. I had mine done last year by a local shop and took them about 20 minutes. I would have done it myself if I had a lift.
  • 4 weeks later...
