Hi, I have a boxster '99 with pcm1, I want to update my system navigation to pcm2 but Porsche has told me its impossible for reasons optic fiber, I am not sure if this is correct, help me.
On the other hand I guess its possible update to pcm1 16bit, It looks to be more powerful than old 8 bit. is it worth? of which the update consists? cost?
Best regards.
Edited by valcax
Porsche are correct - PCM2 is only compatible with cars fitted with the MOST fibre-optic bus system, which means MY03 onwards only.
Yes, the 16 Bit PCM 1 version is more powerfull and is updated with the newest roads and stuff. If the map on your 8 bit system works good enough and is okay updated I would keep it. Elsewhere it is a waste of money.
PS. The price in Europe is around 1700 Euro that includes a new 16 Bit CD-reader and calculator plus hole Europe nav cd´s
pcm1 8 bit has got a problem, last update 2001. Often roads are changing, and when you don`t hope the system takes wrong road, thats the real problem.
Regards.
Yep. I know for sure that the database in Denmark with the most updated version of PCM 1 8 bit system (2001) is VERY VERY BAD. But then again 1700 Euro is also some kind of money. Let me know what you decide.
so am i right to say that if i got a pcm2 i can plug and play in my 04 boxster or is there alittle more to it . is it just a head unit and wack a map cd in or
is there an extra cd reading unit
thanks
thanks
Yes, there is even a PCM2 DIY here in the DIY section. It is for a Carrera but a Boxster is pretty much the same.
