Searched around but most results were using a 996 engine going into a Boxster.
Are there any limitation to using a newer non-DFI 987.1 engine which is 3.4L into a 996? Is there an issue with Variocam Plus that could be resolved with ECU flash? (assume need to run a wire)
How do the 986 folks get around these issues? Seen quite a few threads with them running 987.1 engines....
