I know that in order to program/reprogram a key, an IPAS password is needed. The same tp program a remote. However, is it the same IPAS for each function or a different one. Is the IPAS the same for everything that needs a password or a different one depending on what is being done?
There are several, the only three you really need are the Learning Code, the Immobilizer Code, and the DME programming code. With those, you can do all the programming you will probably ever need.
Edited by JFP in PA
