Does anyone know if it is possible to activate the DRL's on a 2004 US GT3 by using the PST-2/3 or if the DRL's have to be hardwired from the factory. I know there is a hack for earlier 986/996's but would like to know if this is still the case for 04 cars. :cheers:
Edited by Racerron
the headlamps between the canadian car and us car are the same, so it should just be the fuse that you need to put in. i'll ask over on rennlist as one of the people recently did this.
Thanks, any info would be appreciated :D
There is a hack you can do, so you have daytime running light. As far as I remember you just connect 2 fuses. Which ones I don´t remember, I am at work right now so I will have to look into this tomorrow when I get home.
Edited by P.Viby
