Hi all
It's been some time since I had a strange issue, but one came up this week: After driving off I noticed something like vibrations when I pressed the clutch pedal. The clutch worked fine, opened and closed but a little later same drive the feel or let's say the amound of power necessary to press the clutch varied each time I pressed it. Sometimes with vibrations, sometimes without. I drove the car a few times since, the clutch works but the feeling is a different one almost every time. It feels normal from time to time for a few pressures but then again goes harder and I'm 90% sure the point where the clutch engages also varies a bit.
Remote diagnoisis anyone? Hope it's not a part failure...had enough of those ;-)
Ronny
Thanks Loren, I hope its just the accumulator, I had the operating cylinder replaced about 20k mls ago.
Those accumulators are notorius for failure for some reason... The clutch is also notorius for needing to be bled a few times too. So if it starts feeling goofy again after a few days bleed it again. Seems to take a few days for all of the small bubbles to work their way out.
