Guys,
Am having some strange issues with my 2001 Carrera4.
The car has sat for several weeks, with me starting it for a few minutes every week or two.
Now that I finally am able to drive it, I took her for a mellow ride (as opposed to driving like i stole it)
Everything seemed fine until after a few miles of driving at operating temp, several of the dash warning lights came on.
So, I drove it the few blocks back to my house... the whole time everything felt fine.
Turned the car off, checked fluids, hooked up a meter to battery. Everything looks good.
Minutes later I decided to turn her back on, and I get what is in the video linked below...
RPM is constantly surging, the voltmeter in the dash is going from about 11-11.75, several of the warning lights are on, and the instrument lights that are on will dim with the RPM surges.
After that I have noticed that with the key in the ignition, but with the car off, voltmeter shows about 11/11.5.
Check with my handheld meter on the battery it shows just above 12 volts...
Battery is about 3-4 months old.
Any pointers? I am really jonesin to drive her.
Also I should mention, I am suspicious of the accuracy of my handheld meter... it is a cheap one, and several years old.. though seems correct on my other cars.
It looks like you have a failing alternator, or at least a dying voltage regulator. Car should have around14V running and high twelve’s off.
Edited by JFP in PA
Start by double checking your battery by measuring the specific gravity of each cell and a load test.
If it checks out then you are looking at an alternator or the voltage regulator on the alternator as bad.
BTW... normal charging (engine running) is about 13-14 volts.
  • 4 weeks later...
For anyone who found this post via searching:
Replacing my alternator did fix the problem... and if you have to change the alternator, you might as well do the belt at the same time.
I recently had a very similar problem. I was just curious if you tried to replace the voltage regulator in the alternator first before replacing the entire alternator...?
Glad you got it sorted!
I did not attempt to replace just the voltage regulator...
My vehicle has just over 115k miles, so I figured it made sense to swap out the entire alternator.
