We hear that using a 996 turbo rear main seal in an gt3 stops the oil leaks. We have replaced the seal with a factory set up and spacer and on the track it still leaks. So ...when using a turbo seal do you put it in the same as a gt3 (backwards from the engine vacume) or normal?
  • 5 months later...
My understanding is that factory placed the RMS backward by design in order to create more negative pressure (vaccum) for the purpose of attaing a few extra ponies. The downside is the possibility of oil leak if the car is not driven frequently. I suspect that with placement of turbo seal in the conventional ("normal") way, you are likely to lose a few HP (which may not be noticeable). If I rercall correctly, this info was provided by Bruce Anderson in Excellence a few years ago.
  • 6 years later...
