996.1 seat motor drive shaft replacement
One of my passenger seat (UK spec) motors wasn't functioning correctly. Labeled "up / down" in the owners manual, I could hear and feel the motor turning when switched but the rear of the seat pad wasn't raising or lowering. Some research confirmed that this particular function is controlled by a motor which has a flexible metal drive shaft in a greased plastic sheath, leading to gears which raise / lower the seat. The drive shaft commonly breaks... The new part 996.521.609.00 cost £17 from Po
