Still reeling from my last repair bill (rads, condensers, front lower arms, etc) I'd like to try and replace the rear lower control arms on my 1999MY C2 coupe myself. I understand that I'll need a ball joint remover (pickle fork) and an alignment afterwards.
My indie tells me that the rear NS (UK car) arm is worn - I assume that it's best to replace them in pairs?
Access to the necessary bolts etc looks fairly straight forward apart from the ball joint end - any tips for getting at that one? I see there's a Torq socket in the spindle - does that need holding whilst the nut is undone? If so, that looks mighty difficult to get at!
I've found a couple of DIYs covering replacing the front arms - I'm hoping someone who's done the rears could chime in with any advice before I get stuck in...
I promise to photograph my attempts and post them :-)
Andy
Edited by le bouch
