Changing front brake pads on a 997 C4S/C2S
Hi there week end warriors, I hope this post will allow some to jump into the wonderful Porsche DIY world First of all check list of what you need to buy _Do you have the right brake pads oem or aftermarket? oem number 99635194912 _Do you have the extra set for pad change: Pin, clip, spring oem: 99635195911 _Dampening plates, the old ones can be reused with double sided tape but the plate starts rusting, so I would advise to buy new ones, it is not inexpensive the set will cost about
