I installed the smart top module. This is the most easy upgrade ever done to my Boxster. It works like a charm. Highly recommended.
I have a similar product. These are great - not just a way to show off.
Having the ability to put the top up and down at 15-20MPH gives one freedom on city driving to not put the top up at the first hint of rain, but to 'wait it out' knowing that you can get the top up in a hurry when needed.
It extends top down driving into 'almost' bad weather just like seat heaters extend top down driving into 'almost' too cold weather.
I'm a strong proponent of anything which helps keep a Boxster topless :)
Hello Smart Top Users
When using smart top to raised the roof the lid is flush with the rear but I notice the lid is not completely flush with the rear of the boxster when the top is completely lowered. Is this normal?
I am going to swap out the smart top module with the oem and see it it does the same thing later today.
I didn't notice that in my car, I'll have to check it and let you know.
Jeff
Yipster,
The position of the 'clamshell' or lid, will have nothing to do with the installation of the Smart-top. Have a look here for the subforum all about the softtop. Maybe your transmission is not quite set correctly. You'll find loads of useful info in this forum.
