DIY Engine Oil Change, 2010+ 3.8L Turbocharged DFI M979A1
Oil drain plug M18 X 1.5, replace sealing ring, 37 ft/lb Oil filter cover, replace gasket, 19 ft/lb Oil volume during oil change 7.5L Oil volume during new engine build 10.4L 1. Pull out telescopic oil filler tube 2. Clean filler tube with clean cloth 3. Loosen oil filter cover counter clockwise 4. Unscrew oil drain plug, hexagon socket - NOTE THIS IS A HEXAGON NOT TORX SOCKET, AND THE BOLT IS VERY SOFT (ALUMINUM.) YOU MAY WANT TO SWAP TO STAINLESS STEEL. 5. Drain oil 6. Replace sealin
