Hi, I have a 2005 987s and I was looking in to upgrading the navigation software and maps. I hit the MAIN + TRIP buttons and there are exclamation marks against PCM, System Software, Amplifier and CD Changer.
Note that I haven't installed any dodgy DVDs, I am using the original one that came with the car (although I did buy it second hand).
Has anyone come across this before and is this a 'can only be fixed by Porsche' situation, or would buying the upgrade CDs and new maps fix the situation?
thanks
..nick
post-81872-0-58116000-1339853020_thumb.p
If everything is working, I wouldn't worry too much. Not sure, but I suspect it might be caused by past errors stored in the fault memory. I have seen it before, but it usually clears them after a software update.
