99 996 C2, 105k miles. water pump replaced @80k. I recently found a ton of coolant in the intake manifold, the coolant resivoir is pretty much empty now. Let me start from the begining...My car threw misfire codes cel, p0300,p0302,p0306. (I let the car sit for a month) upon trying to start it up, I assesed it had a bad starter-as the battery went dead (recharged it, tapped on the starter) I eventually got the car to start. I ran but extremely rough, tons of smoke coming out of both tail pipes. Ok, suspected bad AOS. while changing the starter, I found a good little puddle of coolant in one of the intake plenums. I think its a cracked head/head gasket. Is it possible it could be AOS???? ****I am not a mechanic.***** just a motivated DIY'er. Any help would be greatly appreciated :)
Sorry to hear this. The head gaskets on these cars simply do not fail. They are multi layer steel.
For the AOS to have caused this - because it does have coolant running through it, - the inner chamber would need to crack or split, and then the intake vacuum enough to pull that coolant into the intake. Sounds unlikely to me, but probably worth checking.
Edited by logray
