I have a problem with the diagnosis of my pcm1 over the diagnosis plug under the steering wheel. I have the pcm1 wiring diagram, and it says that the diagnosis wire from the pcm1 goes to the point vs90, can somebody perhaps tell me where to find that point.
The diagnosis wire from the instrument cluster and the airbags should also go to that point. Is it perhaps somewhere on the relais support? The wire has the color orange/blue, when it comes out of the pcm1.
thank you for your help.
turro
