Hi!
Since I've had my 996 tip car4 I've experienced a whirring sound between 40-65 mph that can be modulated with the accelerator pedal. If you back off from the accelerator, it goes away almost entirely. A trustworthy indy shop suspects strongly the ring and pinion and says that a new tranny is the way to go. I want to know if there are any other options out there. Some questions:
1) Can the ring and pinion be repaired with the existing tranny?
2) Porsche remanufactured trannys are $9700. Can I buy it somewhere else cheaper?
Thank you in advance!
Try Gbox. They rebuild they rebuild the trannys. Also Vertex has rebuilt units. Probably 1/3 the cost of Porsche.
