Hi All,
After 3-4 months of not driving my 2005 997S, I finally brought her out for the weekend. It's quite hot in New Orleans now so of course the A/C was turned on. The problem I have is that the airflow can no longer be directed out of the dash vents. Airflow can only be directed to the windshield and footwell vents. There is some airflow to the the driver and passenger side vents, but I believe it is simply seepage from the windshield and footwell vents.
I usually use AUTO the entire time, and I have also tried using the manual buttons to get airflow to the dash vents. None of these have done the trick. My initial thought was the blower, but I am still getting air to the windshield and floor vents.
What should I check or replace at this point?
You need a diagnostic/test tool as PIWIS or similar for system testing and to trace error codes, it could be a stuck air flap, loose or broken rod, faulty servomotor, etc. without a diagnostic tool it's still a guess.
