I have bought a 997 turbo 2007. My PCM 2.1 have the following status:
PCM S/W version: 1.0
PCM – 04035AD1/0304
System S/W – 03514AD1/5103
Amplifier – 00017500/3504
CD Changer – C38/3003
When I read Porsches installation manuals for the upgrades it does not list my combination (PCM 04035AD1/0304 with Amplifier 00017500/3504). Can I use the Standard Production Status -> Level A -> Level B -> Level C updates with my configuration?
Where can I download the upgrade from Standard Production Status to Level A for my car?
Kind regards
Anders
You will be fine to update that configuration, and the amplifier is safe to update, as it is not the very earliest version. You should buy the update disks from your dealer. I ordered them from my local dealer, and they took 3-4 days to arrive from Germany. They are not expensive. All the part numbers are in the TSBs.
  On 6/2/2012 at 6:05 PM, pureporsche said:
Hey andsch - how did you get at those versions?
Durametric?
Just press MAIN and TRIP at the same time, and scroll and select each module.
