I need to pull the handle a few times before I can open the door no matter the internal or external handle. (internal handle : 5 times, external handle : 3 times)
supposedly it should be just two times I need to pull the handle in order to open the door.
Locking/unlocking is working fine.
it is probably due to wearing of some parts. but which parts?
Any relevant info would be much appreciated !
If the door is locked the inner door released must be pulled twice to open the door, are you saying with an unlocked door you must pull the inner/outer handle multiple times to open it?
If not an alignment issue then the door latch mechanism is very dirty or worn.
yes, need to pull the handle multiple times to open it.
I saw some dirt at the lock.
what parts should I be replacing? the lock? or the handle/latch?
