Spark Plug Change
Note: Part numbers may change over time, so please make sure you have the latest part numbers. Parts you will need: 6 ea 999 170 130 90 Tools you will need: Jack Jack stands 19mm socket for wheel bolts long screwdriver 5/8” Spark plug socket with swivel variety of 3/8” extensions 3/8” swivel 3/8” ratchet 13mm deep well socket E10 open end wrench E12 socket T30 driver Torque wrench Hi temp, conductive anti-seize (not required) Jack up the vehicle at the lift points provided
  • 2 years later...
This is a great diy. However, i would suggest that removing the headers is not neccessary and that this could be completed easily without doing this step. Shiuld minimizee possible problems after. Just a suggestion brothers.
