Changing the Polyrib Belt
Note: Part numbers may change over time, so please make sure you have the latest part numbers. Parts you will need: 1 ea 9A110221601 Tools you will need: Tools to remove rear bumper cover as outlined in: http://www.gettydesi...Rear_Bumper.pdf 30mm open end wrench (large crescent wrench possible) small prybar or screwdriver 16mm socket 8” 3/8” extension torque wrench Begin by removing the rear bumper (see other tutorial). Remove the air filter housing (see other tutorial). Look
  • 9 months later...
thank you for the DIY, so far it has been very helpful. I am having a problem getting the spacer back in, do i need to lift the engine a little bit? Can i lift the engine with a jack and piece of wood? My car is on jack stands, I am also replacing the spark plugs. Not sure if this matters...
thanks!
  • 5 months later...
Great write up! More difficult to change the belt in a 997.2. It took me about two hours to get this done, but I couldn't have completed this job without your instructions. Thank you!
  • 2 years later...
You don't have to remove the rear bumper cover. Just remove your license plate and plate mount. There is an access hole that allows you to remove the spacer bolt.
  • 8 years later...
Wouldn't it be smart to replace the tensioner at the same time? This is my first Porsche, and I'm asking because that's common on the other cars I've owned.
