Hi Loren I have an issue with my 2006 Cayenne 6cyl. The air conditioner works when you are running in open space without stops. As soon as I stop in a light the air starts to get hot until only hot air comes out. There is no overheating issue, coolant needle stays on 180 degrees. Checked the fans and they are running both. Could the coolant sensor cause this?
Any help is appreciated. Thanks
Also checked freon and is ok.
