I recently replaced the headlight switch in my 03 Carrera Cab (thanks for the DIY Loren!) After I got the whole assembly put back together, I tested the lights and they worked! Being not much of a DIYer, I was thrilled. My only problem is that although the lights work, the lights dial on the dash won't stay in the extended position for the fog lights. I can manually hold the dial out and test that the lights are actually working, but the dial won't stay extended on its own. I've taken the dial off and replaced it again several times but I still can't figure out why it won;t extend on it's own. Did I miss a step? Any thoughts?
There are no steps to miss, that feature is a function of the switch - note the switch only locks in the out posiiton if the headlights are turned on also.
Simon
Thanks Simon - you're right! I forgot that the headlights need to be on to engage the fogs. I think it's all working fine - thanks for responding.
