I found this plug which is not connected to anything. It is located under the dash right by the airbag module. Need help trying to figure out what it connects to.
Thank you in advance.
  • 4 weeks later...
Easiest: Updated Becker all-in-one cable: BAS.iPOD
Or
Also seen some people recommend the: BLAU/8-POD2 or 3 (if needing another AUX) (Install info, http://www.discountc...s/blau8-pod.htm)
Or
- Phone power cable – p/n 5001.524-276
- Audio/telephone cable kit - p/n 1319.116-276 [Read that alternatively can use Blitzsafe adapter to charge newer devices: 764244 26241]
Radio pin out : http://mysite.verizon.net/mark00/sitebuildercontent/sitebuilderpictures/004-2.jpg
Edited by 987_RDC
