Hello, I will be installing a new idle control valve today. After installation, is there a special procedure to initiate the new control valve? I know there is a sequence that has to befollowed after installing the throtle position sensor and wonder if the procedure is the same for the ICV. Thanks for your help
Not really but if you want to reset the DME's learning then disconnect the battery for 5 minutes. After re-connect you will need to drive the car for a few miles to re-learn all the settings - it may run rough during the re-learn.
