Hi techies, so today I decided to upgrade the interior center sterio console from boring black to sparkling silver which looks great. However after installing the new unit 2 problems have arose, the first being when I turn on the AC no air what so ever comea out of the vents, the second unrelated problem is the AUX functionality (which connects to my iphone for music) appears to be no longer working.
Everything was working perfectly before the instalation. I mad sure I disconnected the positive battery connection before starting the work, disconnected and reconnected everything back in rite place but no luck.
Regarding the AUX issue, I Recoded the sat nav & re-enables the AUX function (which always defaults to off when you re enter the code). But no luck.
I don't Know what the problem is with the center air vent - its new..... OMG!!! I've suddenly just now rememberd that I forgot to put the internal housing air duct back on!!! Doh!!! Clearly that is why there was no air coming out!
Ok, i still have an issue with tge AUX as explained, i had to wrestle with the sat nav to get it in and out and as i couldnt see much im i thinking i might have cut a cable? But every other function on the sat nav works perfectly.. Just cznt get the AUX to communicate with my iphone. so if anyone can help that would be great!
