I've spotted a set of wheels I quite fancy for my 997.1 C2S, however the offset means that in effect the backs will be spaced out 15mm, whilst the fronts will be spaced out 18mm. I know the back is ok, and I've measured the fronts and I 'think' they would be ok... what do you think?
You will more than likely be just fine, but without knowing the width of the wheels, simply knowing offset change will not be enough. If you can confirm wheels size and offset, I can let you know if you will enounter any trouble.
