Any advice on how to remove the front anti-squeal brake dampeners?
I read the DIY, and the backs just popped off, but I can't get the fronts off???
Thanks.
I guess it depends on where they are stuck. They glue to the back of the pads so the putty knife should separate them there. If the round pieces are stuck in the caliper, as happened to me, it took a quite a combination of penetrant, and claws, pry bars etc to finally get one of them out. No real trick that I found just kept trying.
