Fellow Porsche owners, need a line on trans fluid. I know the OEM 20 liter stuff is recommended but 20 liters for a 5 liter change??? I noticed Pelican is recommending a Fuch Titan ATF 3353 for our TT. Has anyone used this stuff successfully or a recommendation on an alternative that works is appreciated. Kenny.
Use what the factory recommends. You can't go wrong with that. Many folks that have used non approved fluids in both manual and Tips's have had bad experiences. Why take the chance....
The same fluid my be available through Audi or VW (under a different part #) at a cheaper price.. Hopefully someone will chime in and help you with this option.
