Center console removal/short shift kit install
Step by step guide on DIY center console removal and short shift kit install. Works on 987.1 Boxster and Cayman. Has not been confirmed, but may also be applicable for 997.1, 987.2 and 997.2. You'll need a Torx T25 to remove the carpet covered trim and T20 for all the other trim screws.   987.1 Shifter Install DIY.pdf
