Hi guys, i have found a problem with the cayenne (2004 3.2 v6)...over the last couple of mths, when starting it from cold, it seems to misfife slightly and run lumpy for the first 2 mins or so...once warm its ok...
also i was checking the oil level yesterday and i noticed which seemed to be a taping sound from the engine?
now the car has done 80,000 miles, has full psh....i have replaced the spark plugs recently, full service and all coil packs changed too.....
any ideas what could be the problem? or are there any common things to go on them??
thank you
Edited by kp2011
