No response when actuating the rear window glass button. No blown fuses. Is the problem more likely the switch (I can hear it click) or the actuator in the latch itself? Will a PST2 tell me? Do I access this through the interior trim panel on the hatch?
It could be just the switch as the part has been updated. Sorry I don't know the fault tracing needed to sort the issue.
  • 8 months later...
