Little bit of a strange question - adjustable links with stock sway bars? Do you have stock struts? Assuming you've started by adjusting to the stock legth? For adjustable bars, the trick is to adjust them so there is NO PRELOAD on the bar. In other words, you should be able to move the lenth (at least side to side) reasonably easily when installed. Not a great expalnation, but if you put them on you should be able to "feel" them. Hope this helps. Good luck.
